- Jul 17, 2019
- 4,078
- Plaster
- Pentair Intellichlor IC-40
My IC40 is leaking at one of the unions, right at the "seam" where the two plastic halves of the nut come together. It looks like it was manufactured that way. Water is bubbling up at the seam and dripping onto the equipment pad. I can pinch the 2 sides of the nut together and the leak completely stops.
Is there an easy way to fix this, ideally without cutting the PVC? Would some sort of plastic weld/superglue be enough to stop it from leaking?
