My IC40 has not been in use since I bought the house a couple of years ago. Yesterday I did take it out and cleaned it with muriatic acid. I am running it now to see if it shows any increase in chlorine level. In the meantime I have several simple (and likely ignorant, my apologies) questions:
1. When I turn the valve on in the pipe that goes to the SWG, I see a spray turns on into the pool. What is that for? See attached photos.
2. After cleaning, IC40 still shows "Inspect Cell". Does that mean anything other than clean the cell?
3. If in fact I do need to replace it with a new one, what model do you recommend?
Thank you all.
Onder
Thank you all.
Onder
