Hello,
I recently found out that my easy touch panel will show me my salt level but when I go to the diagnostics menu it shows that it is not connected. Can someone explain how to do this? Currently, my salt level reading on the IC40 is Red so there is low salt however, when I test with an Aqua Strip for salt level it shows well over the 3500 ppm, reads around 7 on the strip. Perhaps, the temp of my water is too low to get an accurate reading, it is around 56 degrees or so. Now I am kind of thinking the IC40 was not giving me an accurate reading due to the low temp and now I probably have way too much salt.
Thanks in advance,
Greg
Thanks in advance,
Greg
