ic40 fuse voltage
crackers8199
319
Lake Elsinore, CA
most of the documents I've found online seem to indicate I need a 10A/250V fuse, however all of the ones I can find locally are only rated for 32V. is that a problem? I can't find anything online that will get here before late next week, and I'd rather not have to keep dumping chlorine into the pool in the meanwhile...
You want a AG3, slow blow, 10 amp, 250vac (. 25 inch x 1.25 inch or 6.35mm x 31.75mm)
You can try the 32V fuse if it fits if it is 10amps. Worst case it will blow prematurely. I would replace it with the correct fuse when you get it.
yeah, those are the ones i saw on amazon. every other iteration on amazon all are about a week out, unless i buy a kit with a bunch of other fuse options that i don't want or need. home depot and ace locally both have 10 amp slow blow in stock, but they're only rated at 32v.
does it have to be glass or is ceramic ok? amazon has some ceramic ones that can be here tomorrow.
i ended up ordering the witronics fuses from amazon that were linked above, and they were correct at 250V (not 32V as the previously mentioned review from amazon indicated). they arrived today, i put one in place, and i'm back in business. also, on the plus side, i now have four backups if it blows again.
