- Aug 28, 2008
- 70
- Vinyl
- Pentair Intellichlor IC-60
Hi,
I put in an Pentair IC40 last summer and everything has worked fine until yesterday. It has blown the 10amp blade fuse. I replaced it, and as predicted, it blew the blade fuse again almost immediately. This unit is less than a year old and is used in a northern climate (5 month season). Is there a way to test with a multimeter whether it's failure of the power supply or failure of the unit itself? I ask because the power supply and the IC40 were purchased separately through 2 different pool supply companies. The inside of the IC40 is still spotless and looks almost new.
TIA
TIA
