I think my IC20 might be dying. The power and flow light are both red. The inside panel shows salt level as zero and says check flow/PCB. When I hold down the more button, it shows life at 60%. If have strong flow at the returns and I see stone flow through the check valve.
I installed the cell on February 2005. Is it worth replacing the flow switch or should I replace the cell? Thanks
