I’ve searched and searched but cannot find an answer. I’ve learned so much in my few months of pool ownership about chemicals from this website and I just am learning that my pump has been going full rpms for 12 hrs every day and I have a vsp.
I run it 12 hrs overnight with fountains out of the returns because I’m in Texas with no shade and it helps cool it to 85 at night when it was 92+ before.
My problem is when I just have vsp scheduled the filter pump doesn’t appear to be on and no temperature is read in the IAquaLink opening screen even though in web info the pump is running at the rpms I have set.
After a lot of research (and poolgates previous post) I scheduled the filter pump for 12 hrs and also the lower variable speed I want for that 12 hrs. Now this gives me a green in filter pump and temp reading. Am I doing it right?
Also, is there any way to make my default filter pump button/setting not run max rpm?
In the winter I may make different settings with different speeds at different times which I will probably have to ask help for.
Do I have this set up right? @PoolGate
I
I
