- Jul 26, 2022
- 41
- Plaster
- Jandy Aquapure 1400
I have the Aquapure SWG with the smaller power center (model 6612f), which I believe accommodates 4 relays. My pool is currently controlled by an old x10. Pics attached.
I am trying to figure out what size (rs4/6/8) I need and if I have to get a larger Jandy box to make my system all work.
Components are:
1) Pentair heater (ideally would like to add bypass)
2) Aquapure SWG (I’d like the system to adjust chlorine depending on spa or pool mode)
3) Jandy VSP filter pump
4) Sweep pump
5) Spa pump
6) pool and spa light (wouldn’t be end of world to control this separately via smart switch)
7) spa blower (not sure this is high priority)
The system already has 2 actuators for the spa mode.
Any way to make this work with the existing boxes? And do I need RS8?
Thanks!
Components are:
4) Sweep pump
5) Spa pump
Thanks!
