Hi Folks - First post so please go easy! I found this group after doing some searching for answers to my current issue. Looking forward to learning and contributing.
I have had the iAqualink system for about 30 days now and thus far, it has worked well. I had this system installed as my Wife and I recently relocated from Arizona to California and our home is now a vacation home and we needed to have some kind of remote control/monitoring, along with automation.
For about 3 weeks in December, I had the Maintain Temp feature enabled so it could keep the water at swimming temp for our guests. This past weekend, they informed me they were done with the pool so I turned off the Maintain Temp feature and also turned off the heater. After I did this, later that day I found some of the components within the system were re-named.
In this first shot, the first "Temp 1" icon should and has always been labeled "Filter Pump" and the fourth icon has always been labeled "Waterfall." It now reflects "Heater" but the second Temp 1 from the left has always been my actual Heater:
What is also strange is when I view my Devices, the first label correctly reflects Filter Pump, yet my Waterfall is not properly reflected (shows Heater):
Is this a known issue or could there be a common cause? The only things that *may* make sense is #1, the guy that installed the system and has remote access purposely renamed them (very unlikely) or #2, it's quite cold in Arizona right now and perhaps some rats got inside the unit and might be chewing wires? He also mentioned there was some kind of wire exposed on the ground going from the unit into the control center. Obviously, I have tried checking with him but he is not reachable at the moment.
Thanks Folks.
Thanks Folks.
