I’ve been having the same connection issue described in this thread as well as a few others on the site. My pool is about 18 months old and everything worked perfectly until Jandy did their server maintenance at the end of March.
When I called Jandy tech support about the issue in March, I was told they migrated to a new server during their maintenance outage. The rep said that the new server had some bugs they were working through. He told me the server upgrade was done so that they could support a new and improved app user interface, where they were planning on merging the regular app functionality with the “web” tab functionality. He said that they had been experiencing some isolated outages after the maintenance period, but they would be resolved soon. That was over 3 months ago and still having issues!
During the last 3 months I have called tech support well over 10 times without any resolution. I’ve gone through a whole litany of troubleshooting exercises, from resetting the app, reinstalling the app, resetting my profile location, resetting my entire online account, resetting my system remotely through Jandy’s network, router resets and antennae replacement.
My internet bandwidth was also measured at over 50 mb per second where my antennae is located and it has all signal bars showing up. This was measured at the same time I experienced a connection freeze.
We escalated to my local authorized Jandy repair company and they were unable determine the issue, so they brought out the local Jandy rep to investigate.
They both agreed it was likely a software issue on the server side and not anything hardware related. Several inside tech support reps and my local rep have said all customers with this connection issue all have att internet service. Although my internet provider and router are the same today, as they were when my pool was setup 18 months ago and working fine, they think there may be a connection with att customers having this issue. However, my neighbor with identical Jandy setup and att router has no issues.
When the Jandy rep came out, he was confident that another reset through the Jandy network would do the trick. I told him that I’ve done that multiple times over the phone with tech support and he assured me that he was doing some sort of advanced reset that hasn’t yet been done on my system. Just like all the other resets, it worked for an hour or so then went back to having the exact same connection issues.
The Jandy rep assured me they would make it right, but after 3 months of not having a properly working system, I’m fed up with the excuses and lack of resolution.
That brings me to my first post on trouble free pool!
Has anyone else with this connection/freezing issue gotten it resolved? If so, what did you do?
Can you also mention who your internet service provider is?
Mike
I'm where a bunch of you are now, I have the orbi, I have the Iaqualink, it worked fine for 2 months, (at least I did not notice a problem but it's winter so only occasionally have I used the app, they were able to set it up without issue at least. About 6 weeks ago I had my first occasion of the app telling me I'm offline. Through a ton of trouble shooting the best I can understand is there is something with the Orbi router that conflicts with the Iaqualink and when you try to access the app/ website control is when it loses connection. The local Jandy rep was out today and replaced everything, it made no difference. It's not a signal issue, which is obvious...and the whole reason we all got an Orbi is we don't want poor wifi signal around the house but the work around is to have a different router running 2.4ghz only and just connect the iaqualink to that.....even at 1mbps I'm oeprating fine. As most do with the Orbi I deactivated my wifi on my att router, but now I had to turn it back on (make sure it's on a different channel from the orbi) then it so far has connected fine and kept the connection. Another work around would be to hard wire the Iaqualink but if this holds then there's no reason to.
Oh by the way I called netgear support which I thought they were being helpful until they started blaming my computer (having a computer or not having a computer has no impact on this issue) and they wanted me to pay $200 for them to first fix my computer THEN they could fix my disconnecting issue, this is purely a scam.
