Moved from HERE
New to this forum so apologies if I should be starting a new thread.
I have pretty much the same board as the OP. I also have the same PDA board as above. Rev. 7.1. However the installer (before my time) has pasted an RS wiring diagram in the cabinet.
I have an iAqualink IQ900 kit that has been connected via CAT5 and worked until recently. Recently it started disappearing off the network for days and then coming back on its own. Now it won't come online at all. CAT cable tested and fine. Light just stays red on the IQ900.
So two questions:
1. I keep seeing that the PDA version cannot be controlled from the web, but I can (used to be able to) log into iaqualink.zodiacpoolsystems.com (from anywhere) and control my pool equipment, including schedules, etc. With the kit pictured, can someone explain how I can do the web control bit without the RS board?
2. Is it common for the IQ900 (hard-wired) to fail? Looks like the cost of replacing is US$500 or so? Can I replace with the IQ3.0?
Many thanks for any thoughts.
Hi all,The kit Allen above listed will include a WiFi antenna and a board like the below (the pictured board is a PDA board, the RS board will say RS on it) which goes onto the back of your main board. Once you swap that board, the personality of your system will switch from PDA based to APP/Computer based. You'll like it a whole lot better. Make sure you are buying the IQ30-RS and NOT the IQ30-A! I have done this swap myself and it is very easy.
You can most likely sell your old PDA and antenna (even broken) on ebay for a couple hundred dollars.
So two questions:
