Walt,
The
first thing that has to work is the flow light.. If you have a red flow light, nothing else will work, including the salt test.. (Railroad crossing-like flashing lights.)
You either have good flow or you don't.. It is that simple.. If you can put your hand by a pool return line and feel a good strong flow, then the flow switch should be closed.
Let's assume the flow is good.. That means the flow switch is not working or the cell itself is bad.
You changed the flow switch assembly... did you have a red flow light before you changed the flow switch? It could be...
You put the flow switch in backwards..
You bent it when you installed it..
The connections are not good.. (Not unusual with the crimp connectors)
Or the cell is bad.
You can
temporarily short the Red and Black wires coming
FROM the cell together as a test. This simulates the flow switch closing. If the light turns green with the wires shorted, then the problem is the flow switch or connections.. If the light does NOT turn green with the wires shorted together, then the cell is bad..
Here is a diagram that shows the connections.. This diagram is for adding an external temp sensor, but also shows how the flow switch is connected..
We have also seen some black corrosion reported on the wires between the cell and the flow switch assy.. If yours are black they need to be cleaned or scraped to make a good electrical contact.
Jim R.
