In May 2021 I replaced my six or so year old Hayward T15 with a rebuilt unit which was allegedly provided with the same cell that Hayward uses.
I recently replaced the water in my pool. It is betwixt 18K- 19K gallons.
I put in 480# of sodium chloride. Unfortunately I did this with the SWG connected (while the SWG cell was still fouled), but I put the salt in the shallow end of the pool in front of some pump return jets, far away from my intakes at the other end of the pool, so I doubt I gave the SWG/computer a shock.
Iben having troubles with the SWG running for a bit then turning off, telling me there is insufficient salt.
It runs at first and then shuts down - "chlorinator error - check salt level"
My salt level is at slightly less than 3000 PPM according to Leslie's a @couple of different stores, and 3200 to 3400 with my Taylor K-1766 kit, stored indoors.
I repeat the Taylor tests with the same water sample over and over using a mechanical/magnetic mixing engine and get repeatable results each time; the difference between 3200 ppm and 3400 ppm is a single drop of reagent R-0718, so as y'all likely know, so the difference of 200 PPM in my measurements is not significant.
Here is what the computer thought was going on with the SWG about the salt level as it was starting up this morning (taken from photographs of the computer screen)
The first entry at 48 seconds was one or two seconds after the SWG fired up after the programmed delay:
I went out about five this evening and the SWG was still working, showing around 2100 PPM salt.
What is this wandering and wildly inaccurate PPM reading I am getting from the computer?
I hesitate to add more salt, as 480# is pretty close to 3200 PPM in my pool.
Help Cecil! Help!
mac
- they charge me for differing amounts ever time they fill it!
- Do you think the pool volume changes????
TOD (sec) | READING PPM | voltage | current amps | power watts |
48 | 3100 | -26.74 | -6.3 | 168.5 |
51 | 2200 | -27.36 | -5.03 | 137.6 |
53 | 2100 | -27.53 | -4.8 | 132.1 |
2 | 2000 | -27.53 | -4.66 | 128.3 |
Help Cecil! Help!
mac
