So I set up my pool timer recently and when it didn't trigger to turn off in the evening, I looked at it and it looks like the off toggle was lodged sort of behind the timer wheel. I wasn't able to turn the switch to off, seems like it was jammed. It was tough to remove so I had to take a small rock and tap it off.
Now it seems the pool timer doesn't move. I can turn the pool on and off though. My guess is that I wasn't paying attention on the placement of the on off toggles so the timer moved and passed the on switch as the pool was already on.
Any recommendations to fix? If I have to replace, is it DIY-able?
Thanks TFP!
Thanks TFP!
