- Jul 10, 2018
- 1,238
- Plaster
- Pentair Intellichlor IC-60
I was at the local Leslie’s Pro to pick up some 12.5% LC. I saw a new pallet of still wrapped 4 pack boxes. Next to it was a half pallet so I grabbed a 4 pk box and looked for the date code. Top, all 4 sides, even tilted it a little to look on the bottom. No date code.
I looked at the new unwrapped pallet couldn’t find a date code on that either.
I thought, oh well, I need chlorine. The pool water has dropped into the upper 50’s so I had turned off the SWG. The counter person was a young lady and I decided not to ask her about the dates.
Well, I got home and opened the 4 pk. Couldn’t find a date code on any of the individual gallon jugs. So dummy me, I used a half a gallon, then measured a couple of hours later. Expecting to see at least a 2 ppm rise, I got the same reading as before the addition.
Although, I was still at 8 ppm the next day, I added a full gallon. Tested a couple of hours later and it only raised FC to 10ppm. Pool Math indicates the rise should/could have been 4.8 ppm for 26k gallon pool. So I should/could have seen 12.5 ppm and only got to 10 ppm.
I figured I can’t return it after using a gallon and a half from the 4 pk. I learned my lesson, no date code… no purchase.
