Greetings,
1. 21,000 gallon free form gunite pebble tech pool with spa. Chlorine based. Built in November of 2017 in Middle Georgia.
2. Coming out of winter this year, noticed we were using a high amount of Chlorine tablets....pool turning very light green. What you noticed is that it was slightly cloudy. pH was acceptable (7.7). Decided to use my TFP test kit finally. TA was high (190), FC (2ppm)....and CYA 100.
3. Called pool builder and said run filter (Variable speed pump) at highest setting. In addition, I decided to change out 3.5 inches of water. I ran filter high speed overnight (12 hrs) with no change.
4. Ran CYA test this morning...90-95 ppm. Wife showed me chlorine we had been using....had trichlor and dichlor.
5. Currently draining pool down 3/4ths (3 inches above shallow). Scrubbing side walls of pebble tech as its draining.
6. Will start filling back up this evening.
7. How should I proceed from here on out? I have concerns that my CYA could still be 100 after I fill back up. I know add liquid bleach only, i get that now. I just retired from the Air Force so I have time now
. Any comments would be welcome!
