our pool was covered all winter and I’m just getting around to cleaning it.
This is like nothing I’ve seen before. It’s a swamp.
Besides the algae, which is going to require a tremendous amount of SLAM and magic, I can’t vacuum the pool more than 5 minutes before clogging up the pre-filter basket. I’m already on my 3rd pleated filter, and so far have only done the Baja ledge (8x7 rough guess).
This is my 3rd or 4th solar cover, I normally change them every spring, I’ve never seen one deteriorate this much, this fast (sun2solar). I can’t even see 2’ deep, but it appears there is so much muck and leaves, which is also unusual.
Also, the main breaker is tripping, so who knows how long the pump didn’t run for.
The only thing I’ve noticed is the wiring to the heat pump pressure sensor is chewed up in a few spots. Hopefully that’s the culprit.
What on earth do I do? Short of spending $500-1000 for an external vacuum, can I get an electric pump to hook up to my vacuum to start sucking all the debris out and replacing the water? It’s fiberglass so I can’t fully drain it, so it’ll be a long process.
Got the pool around 2019. Every spring I go in and spend 2 days vacuuming and balancing, and it’s crystal clear and holds chemistry very well all year.
I haven’t even tested the water yet as there is absolutely no point at this time.
