Hello,
I have a 2006 hydropool Platinum Series Serenity Spa and I have a HOt error that will not go away. During winter, the hose BIB cracked leaking out all the water leaving the spa drained. I found the issue about a months later and displaying HOt (solid).
This past weekend the tub was refilled, all the air was purged from the spa (2 x pumps via plugs and pump unions) and still nothing… My instincts tell me everything is ok and a relay maybe stuck.
What I know:
The high temp sensor reads 60.7 ohms, while the other sensor reads 61.5 ohms. The Balboa 4kw heating element is at 14.3 ohms and 240v. The water temp is around 57F or 14ish C. The read out tells me the sensors/heater are working but I'm unsure where I should go next? My system doesn't have a noticeable pressure/flow switch to test, and not sure if there is one present, but hidden or out of sight.
I'm pretty capable, so please don't hesitate to have me troubleshoot the board.
What I know:
