The Hurlcon VX chlorinator is more than 10 years old. It always says low salt which I think it's true because I didn't add enough salt to the pool after heavy rains. The chlorinator works properly despite the low salt warning.
A few days ago I added 1 bag of salt to the pool. After a while I went to check the chlorinator and found the no flow light is on. Thought it's a false warning and restarted the chlorinator, after the initial 5 mins running, it still had the no flow warning. Tried a few time and it's the same.
The cell was clean enough, only a little bit calcium deposit on the edge of a few cell plates. Anyway I took the cell out and soaked in vinegar as I did before to clean deposit. Noticed the flow sensor was also covered by a thin layer of deposit so cleaned it as well. After cleaning the cell, I put it back and tested again, the same no flow error.
I took the cell out again and soaked it in a bucket of pool water, connected it to a 16V power supply. The cell started to produce chlorine.
Now not sure if it's chlorinator the problem, or the cell is weak from corrosion and can't pass the check of chlorinator.
To sanitize pool for now temporarily. I connect the pump and the 16V power supply to a remote control power switch, and connect the power supply directly to the cell without the chlorinator. Now it works to add chlorine to the pool.
Will take both chlorinator and cell to a pool shop to find out which one failed.
Anyone has the similar situation?
