I made the mistake of calculating daily chlorine loss about 2 weeks ago and just adding the recommended amount from that point, every morning. Pool temperature and weather has changed since then, so I'm assuming my needs have changed. Anyhow, we finally got to swim yesterday and I was surprised when I did a chlorine test this morning and found we were at 1.5ppm. I did not test yesterday morning, so I am not sure what the starting point was, but I know that I added 2.5ppm in the morning. I immediately added enough to bring it up to 8ppm (tested 30 min later and confirmed 8ppm). I also tested everything else:
FC: 1.5 (brought up to 8ppm at 6:30am)
pH: 7.8
TA: 80
CH: 350
CYA: 40 (have a sock in there now to get to 50)
I will be doing an OCLT but am wondering if anything else might be using chlorine that I should look out for. We do have a horribly placed Crape Myrtle that has been having me clean the skimmer at least a couple of times a day.
Any assistance is appreciated.
pH: 7.8
TA: 80
CH: 350
