- Nov 12, 2017
- 12,677
- Plaster
- Pentair Intellichlor IC-40
Thanks for taking it as I intended it.Thank you for your honesty. It's definitely better to know sooner rather than later.
That is a great approach, and I'm glad to hear you've got things squared away with the neighbor.Note the framing is just sort of a "proof of concept,"
Keep in mind that the pump only needs to overcome the initial fill. Once the water is flowing to the roof, the water coming down is "pulling" the water up the other side (simplified explanation). So once the panels are filled, the pump has much less to do. Mark is our "pump guy." If he says it'll work, it'll work.I didn't know if my pump would be strong enough to reach the roof,
All good stuff! With ya.I thought that throwing together some 2x4s was less of a commitment to get my feet wet (so to speak) with this solar experiment. In the back of my mind I also thought that once I get the system working I would consider moving to the roof, either to move the entire array there or to add an additional array.
Bummer, not with those panels anyway. I was projecting some. My roof is like your neighbor's. I filled one side with pool heater and the other side with PV panels. I kind'a lucked out. If it helps, all my pool solar is on the north side. I was told (especially during the summer), the sun angle is much less critical than with PV solar panels. In fact, the sun really arcs over the north face at least as much as the south face. That's not true in the winter, but I don't heat my pool in the winter. I saved the south side for PV. I expect in Arizona, in the pool season, your panels could be on any facet of your roof.Second, my roof is not really optimally situated for solar.
And yes, the array doesn't all need to be together. You can split it up as needed, but you do need to be aware that the connections (the plumbing schematic) are somewhat unintuitive and have to be arranged properly so that water is flowing from sub-array to sub-array most efficiently. That website I gave you explains how to do that.
I would guess not. (1) The entire array is going to be expanding and contracting quite a bit, all day, every day. If the tubes are touching the roofing material, especially over the ridge, that dragging and sawing is going to mess up those tubes to the point of failure, in short order. I could go on for pages about what I did to make sure no part of my array, manifold or tubes, touches the roof. Only the mounting brackets and the pipes. That's the ideal.When installing long solar panels on a roof, can I drape the panels over the ridgeline or use them in a 90 degree turn?
(2) More importantly: solar panels are supposed to fill from one bottom corner and return from the opposite upper corner. You have that exactly right. But if the panels are folded over the ridge, that is no longer going to be the case. I don't know exactly what the ramifications of that would be, but I would expect it could greatly reduce heating efficiency, or it might not even work at all. Maybe @mas985 would know.
I know that you have to accommodate expansion and contraction (as described above), and you have to account for wind loads. The mounts that came with my system do both, so I didn't have to learn or engineer anything in that regard. I just followed the instructions! Sorry, it's outside of my experience how to deal with those factors on someone else's array. Perhaps if you can identify the manufacturer of the panels, they can assist and advise what mounting system is appropriate for your installation. I'd call them as a first step.Any other mounting recommendations? And what hardware will I need?
I like that idea. I fly a shade sail over my pool, because even while in the pool the sun can be too hot. I expect AZ is even worse on the ol' noggin. I'd be tempted to build that pergola out over the pool a bit. That will reduce the sun on the water, so kinda contradictory to the heating effort, but I'd want a little area of shade that I could hang out in while in the pool. Better than umbrellas, which a lot of people use for this purpose, or shade sails like I do, because it would be permanent and totally stable (wind-proof). And maybe even accommodate an extra panel or two. So you might think in terms of getting a two-fer out of that pergola. I have two, and that's where everybody hangs out, under one or the other. So you'd be getting a "three-fer:" mounting for your panels, shade for your pool, and shade for your yard.BTW my other thought was to build a pergola with a slanted roof in the area between the pool and the house
And you can always put some on the pergola and some of the roof.
Keep up the research and the brain-storming, you'll get there.
