I have a new (installed in October) Jandy heater that is making a loud Howl or whine. The symptoms are very similar to the issue described in this posting:
The noise starts a few seconds after the burner lights.
The burner often takes multiple tries to light (you can see the igniter heat up, hear the gas come on and then shut off again the first time it tries).
Once the incoming water reaches about 90F the noise goes away (observed while heating the spa).
The heater is under warranty, and so far the technicians have tried:
Replacing the blower
Replacing the Gas Valve
Replacing the Thermal Control Valve.
Replacing the integrated bypass mechanism.
We have also had the Gas company out to check pressures, and find that is well with in spec (9.7 in WC static, 7.5" wc when the heater is running).
The heater is in a shed and is vented by about 6 feet and two 90 degree elbows of 4" Cat III flue so it was thought that the flue might be an issue, however we have tested disconnecting the flue at the heater and it make the same noise.
Any thought from the TFP collective?
