How to switch from Enviroswim to SWG or Chlorine
Avo1
0
Sep 10, 2017
15
Brisbane Australia
Hi,
I am nearly converted.......
As a trial to stop my pH increasing I would like to try my pool possibly on liquid chlorine. I think this can be done with just turning off my Enviroswim system and adding the liquid? I think I will not have to replacing anything for the short term?
If this works, do I stay with this or convert to SWG or ....?
Will I need any other testers other than a Taylor K-2005C?
Thank you to you all, you have been of great help so far.
Avo1
Following...
(I would tend to think you won't see any difference. Liquid chlorine sanitation is mostly pH neutral)
I have read the pool school stuff - awesome, which should not be a problem, but should I be aware of anything? Can anyone foresee any problems with the residual copper (0.2ppm) in my pool whilst trialling liquid chlorine? I cannot remove the water as I am just about out of tank water...... we need rain!
I should be right to follow the calculator without worry?
