How to set Solar Heat *and* pump speed in iAqualink?
dpl252
Active member
Jul 21, 2022
36
Clayton, CA
Trying to see if it's possible in iAqualink to set solar priority to turn on solar heat when air temp is higher than pool temp AND ALSO increase pool pump speed with solar heat is on.
Currently my schedule is set to 10am - 7pm to turn pump on, and is set to regular speed (2000rpm). I was trying to run the pump at 24/7 at a lower rpm but was struggling to get reliable flow on my Jandy Truclear SWG (I know it's not a great model but it's what I have and i'll use it until it fails). So currently just have it set for 9 hours during the day which seems to be enough. The issue I'm now trying to figure out it, I want to set Solar Heat to turn on when the temp is higher than the pool temp (as opposed to just scheduling specific hours to turn it on then off).
How can I set this in iAqualink? Also, is it possible to trigger a VSP Speed Adjustment based on if Solar Heat is enabled? If my Solar valve is open, 2000rpm isn't enough to send the water to the roof and still get good flow out of my returns, so I usually bump it up like 2700/2800 for Solar.
Show us your VSP Speed Setup page.
I think there is an entry for Solar on the newer Rev versions.
@MSchutzer @PoolGate may know.
