I installed a Pentair Clean and Clear C-160318 filter. I may have had too much faith in the unions on the inlet and outlet. I figured the engineers had worked it out so it was simple to close them. Instead of sealing them up and then attaching pipes to them with glue, I attached the pipes first and planned to seal them later.
The O-rings don't seem to want to seat anywhere. I thought they might seat themselves when I tightened the collars, but they do not.
Is there a trick to seating these things, or should I just cut the pipes, seal them up with the filter on its side in the yard, and then use cemented couplers to put the pipes back together?
