We inherited an ageing pool that we're trying to keep going for a little while longer until we can afford to update it. I managed to fix a couple of leaks in the waste line by cutting out old bits of pipe and gluing in the new sections, and that worked fine.
The latest leak though, is from a hairline crack in a pipe immediately next to its junction into the multiport. My original plan was to saw off the pipe at the junction with the threaded bit going into the multiport (which appears glued in place), and then insert one of those joiner pieces that slots inside the pipe one side (mulitport side) and is standard pipe width the other, ie can then be joined with a new section of pipe.
My concern is, having done that, how do I now insert a new section of pipe given that both multiport and pump are fixed? i.e. don't I need to move them apart to get a new section of pipe in, then glue & push it all together?
The connection into the pump has a joint that looks as though it should unscrew, but it won't budge - and I'm concerned if I force it, it'll bust the actual join into the (Sta-rite) pump below - which seems to be held with some kind of sealant!
Any ideas/help really welcome!
Thanks!
Thanks!
