How to repair automatic safety cover
AStevens
61
Surrey
Hi guys,
So we had a storm and a branch fell and punctured our automatic safety cover, I got a patch kit to place on the cover. My question is, if the rip is bigger than the patch can I use multiple strips to repair? the hole is about 10" long by 7" wide, punctured in a "t" shape. Can you use two long strips that over lap in the middle with adhesive to seal the cover?
Thanks!
Rocket J Squirrel
835
Alamo, CA
A better and easier way would be to get some of the original vinyl from either the manufacturer or your cover maintenance company if you have one. Then you can cut a single big patch. My cover installer/maintainer always gives me some extra vinyl and a tube of the cement for free when they service my cover if they have it and I ask for it (which I always do).
AStevens
61
Surrey
I will see if they are able to provide me with a big section of it, in the case they cannot, can I still use multiple pieces to seal it? ( would just need to overlap well I assume? )
Rocket J Squirrel
835
Alamo, CA
I have never had to try that, so I can't speak from experience. I think it will work if you do it in stages. Let the bottom patches dry, then put the overlapping piece on top. Be generous with both the patching material and the glue.
AStevens
61
Surrey
I can do the length just not the width, I wonder if I have to use multiple pieces, should I just go from one side to the other with an overlap in the middle?
