How to remove Green/Yellow Spots from pool
Sergiopichardo
1
California
Moved from here.
Because some of those Yellow products are ammonia. That just chews up your chlorine and complicates issues. Then you have to get rid of the ammonia.... what a waste of time and money.
Some also contain Bromine which changes a chlorine pool into a BROMINE pool for *evah!* and the only way to get rid of Bromine is to drain it out. Each time you add chlorine to it you're just re-energizing it up again! Again, another nuisance to chlorine pools and a waste of money.
Does that help explain it better??
Maddie :flower:
Thank you Maddie, I was going to use this product but because of the information you provided I change my mind. Any better way to treat geen/yellow spots on pools?
Welcome to TFP! :wave: Looks like your post was moved from another's thread. Can you post a pic or two of the spots? Tell us more about your pool by updating your signature (see mine as an example) and tell us how you chlorinate the pool on a daily basis. In addition let us know what other products you have added to the water in the past from a pool store (i.e. algaecides, etc).
Pool Care Basics
