Our PB completed the plumbing setup before the inline heat exchanger was available for installation. Now that we're installing, I'm not quite sure the plumbing is set up quite right. Would really appreciate any advise/observations on the setup and how it really should be arranged.
As you can see in first picture below, all pump equipment is in the garage, 10 ft below water line. Beginning in left corner, pool water comes down into pump, through filter, then through the grey heat exchanger section, and then back up and around through SWG before heading back to pool. In the way the plumbing is designed/arranged, is the idea that the water is supposed to come from filter, some (but not all) of it is supposed to go up the first grey column and through the heat exchanger and then back down the other grey leg to join with the water that is going straight along floor from filter to the return line? As you can see, there are Jandy valves on each leg, plus a check valve on the righ-hand down pipe below the heat exchanger. I would have thought the purpose of the check valve is to prevent backflow into the heat exchanger, though it now seems to be installed the opposite way (see picture at bottom). If that is all right, what is the purpose of the grey crossbar midway up the wall between the two Jandy valves. To create further bypass? What is the right position setting for each of the Jandy valves? Sorry for the noob question and appreciate the group's wisdom! Thank you.
