If you can send your suntouch to me, I have original programmers that don't need converted S19 files, so it most likely will work.I've confirmed that i can erase the flash, write the s19, and then read it back. My problem is that I don't know what it wrong. The original Pentair s19, the converted S19, and what I can read back are completely different.
I don't know enough about the format to spot any issues.
I've attached the original ,my converted file (Out), and what I've read back after writing it (ReadOut). Can someone take a look? Or can someone send me their SunTouch 2.090 s19 file for the USBDM?
Thanks!
What programmer are you using?Hi,
I followed the instructions for my SunTouch controller and the flash programming failed. I tried programming with EraseSelective, EraseAll, TargetDefault, and EraseMass. None worked, but now the controller won't boot.
I was trying to update to the latest 2.090 firmware (from 2.020). I converted it to MC9S12A64.
Any ideas how to fix this?
Thanks
Can you show a pic of the microcontroller on the Suntouch?Freescale USBDM. I updated the firmware to latest before starting.
Yes, it returns as MC9S12A64. Even if it only has 64K of flash, the bad erase/write data shows up before 1K. Also, if I choose a part with less storage (e.g. MC9S12A32), the programmer returns an error before trying to erase/write.By read the chip, I mean does it detect which chip is on the board?
It sounds to me like you are just running out of room. My guess is you only have 64 kilobytes of memory on the microcontroller.
I would imagine you could get an easy touch controller and have more functionality. Or maybe even an intellitouch. With a lot of people upgrading to intellicenters, there are plenty of secondhand boards out there
I'm in central Orange County (Tustin/Orange)When my neighbor upgraded to his intellicenter, I grabbed all of the internals from his intellitouch i7+3.
I plan to try my USBDM at some point to see if I could upgrade the firmware on the MC912. I remember reading somewhere that somebody figured out how to get it to program these chips.
Problem is, I don't have an extra transformer sitting around to power this.
What part of socal are you in?
