My pool is currently leaking due to an ASR situation; water level in pool is currently below the 2 skimmers but just above the drain on the side wall under the skimmer, assuming that is why there is some water still in the skimmer that I'm trying to fully empty so I can seal some cracks in the skimmer.
My spa is also maybe 6 to 7 inches below where the normal water levels need to be; i've currently turned off my pump, how do I shift some of the water from the pool into the spa so I can hopefully clear the skimmer of any water?
