Hello, I'm new here and did not seem to find my particular problem on the forums. I have well water which is extremely alkaline. Ph is way above my ability to measure. It takes considerable dry acid to get it down below 8. I add 2 tablespoons at a time every 2 hours to bring it down. It actually takes a couple of weeks to stabilize the Ph. By that time I have also removed the TA but if I add Sodium Bicarb the Ph goes up again. How do I lower Ph while raising TA? My current numbers are: Ph 7.8, TA 70, CH 220. I recently added Boric acid. 1 lb. Have I made it more difficult to change my Ph? Should I use Muriatic acid since my Ph is so high?
