How to increase CSI value?
Running your pH at 7.8 is the easiest way.
You can increase your CH by 50-100 ppm.
Where are you located?
Located in north Texas. I do have some calcium scaling on my mortor. Maybe adding CH will help with that.
It will not.
Your CSI will go up as your water temperature goes up into the summer.
You do not need to get your CSI to 0.
Run your pH at 7.8 and within a few weeks your pool water will be warmer and problem will be fixed.
No action required. With a TA of 70, your pH will slowly rise on its own. Maintain a slightly negative CSI (0.0 to -0.3) to prevent scale, especially on your SWCG.
Your CH will slowly increase over the summer with fill water and evaporation. What's the CH and TA of your fill water?
Now would be a good time to increase your CYA to ~80.
