First, a little background. Have been self managing our pool/spa combo for over 10 years. Until the recent (5 weeks ago) replaster, was using chlorine tabs with an inline feeder (yes, CYA was always high) and the pH as well as other chems were very steady. Was using a pressure side cleaner daily which stayed in the pool. Also have a Nest Cam pointed at the pool. All of this made travel easy, only necessitating a friend to stop by after a week to refill the chlorinator and empty the cleaner bag if needed.
As part of the prep for the replaster, I discovered TFP. I have seen the light and have switched to adding liquid chlorine daily, about 36-40 oz. As you know, and I wasn't aware ahead of time, the pH is still rising as part of the cure process. Currently requires ~28 oz MA daily. Love the new robotic cleaner but I put it in and remove after it's done. So the question is now how to handle these tasks when leaving on travel/vacation. I can't trust friends/neighbors with this activity.
Sanitizer - Currently thinking to revert to tabs while away and switch back to liquid upon return.
pH - This is the biggest problem. I'm wondering about adding a Pentair IntelliChem, Pentair IntellipH or simply a Stenner pump/drum combo with a timer.
Cleaner - Currently thinking to revert to the pressure side cleaner while away and then back to the robot upon return.
What advice do you guys have? How do you handle this situation? One option is to contract with a pool service while away, but this would get costly and challenging for daily MA addition. Thanks for your recommendations.
