The two products I have are brominating concentrate and bromine tablets.
Brominating Concentrate:
- Sodium Dichloro-s-triazinetrione: 52.7%
- Sodium Bromide: 14.7%
Bromine Tablets:
- available bromine as 1-bromo-3-chloro-5,5-dimethylhydantoin and related hydantoins: 68.4%
- available chlorine as 1-bromo-3-chloro-5,5-dimethylhydantoin and related hydantoins: 28.2%
I found this comment on how much sodium bromide is needed (conveniently enough, for my spa volume of 420 US gallons):
order to get 30ppm Br- bank in 420 gallons of water, you need about 61.3 grams or 2.2 ounces of sodium bromide. It's really not super necessary to be that accurate as the bromide bank is just there to act as a reserve of bromide ions so it could be 30, 40, 50ppm or whatever is easiest to add. 30ppm just ensures you have enough bromide in the water so that if you want to shock the tub, you can get up to the 20ppm bromine level easily. Bromide doesn't go away so you should only need to create the bromide bank once per fill and then it's good to go.
Using brominating concentrate, I would need about 417 g of it to reach 61.3 g of sodium bromide. That's a lot of chemcial, especially since it contains ~200g of dichlor! That doesn't sound very convenient...
Using bromine tablets, there seems to be a much better ratio of available bromine to available chlorine, so that seems at a glance like the way to go. The only problem is, I'm not enough of a chemist to know what the ratio of bromine to bromide is... If it's 1:1, then adding 90g worth of crushed bromine tablets should result in a bromide bank of 30 ppm in my tub. Also, I'm not sure what 28.2% "available chlorine" would mean in terms of free chlorine levels, i.e. how much I can safely add in one batch.
Hopefully someone with a bit more chemical knowledge than me can confirm what that ratio is so we can do the math
