Hi all
I've got a Plastic AGP and I'm plumbing all the kit up with standard 1.5 inch PVC pipe.
However... just realised my Bestway SWG (Flowclear™ Hydrogenic 6 g/h Saltwater Chlorinator, as per image) has different size fittings. Measuring the thread, I think it's 2 1/4 inch (about 56mm?). How do I connect my 1.5 inch PVC pipe to this?
It came with one hose (not two) that has a female connector to screw on to either side, and on the other end, the same. There's also one (again, not two!) hose tail type connection that will screw onto the male thread and that then provides an option to fit some kind of hose... narrower though and doesn't help with the 1.5 inch pipe.
Can't see to find any relevant Intex or Bestway (same size I believe) convertor online, but I may be using the wrong terminology... any ideas??
I'm based in the UK.
Thanks all
Thanks all
