Finishing the SLAM requires three things...
A. Pool water should be crystal clear with no sign of algae anywhere
B. CC's test result should be .5 ppm or less
C. You should not lose more than 1 ppm FC overnight.
So that residue at the bottom of your pool causes you to"fail" the SLAM because your water isn't crystal clear by the TFP definition. Sounds a little picky at first but it's reasoning is solid. You don't want ANY type of debris. Is that residue now gone?
PS - not sure what a chlorine ball is. Is that CYA 46 from your own testing? If so, always report CYA in increments of 10 (30 ppm, 50 ppm, etc) and always round up (46 CYA report as 50 CYA)
