Dirk I always put a hair of pitch on my copings. Standard way is to have a 12" level with the bubble touching the back line. On complex pools and with waterfalls that changes. When adding a waterfall or sheer decent wall you slowly adjust amd pitch away from the feature into the pool so water doeant collect at the bottom. There are lots of coping installed dead level and just the deck has slight pitch. Sometimes you have to level it for the shape and lay of the pool
Jimmy, wife has a question about the grout spacing between our coping pieces...since the grout lines on this first install are unsightly can they but them up against each other and float just a hair-line of grout to fill the small gap? Installer didn't use spacers to begin with, just eyeballed it. Didn't know if the grout lines were even necessary.
