How often do most of you drain your H20 in Phoenix area and why do u drain when you do? Are you measuring CH or have u learned by now that your pool needs it every "x"/years? Then, the reality is that for those of you who drain less frequently, u r probably a disciplined rock star as far as caring for your pool because I think that matters.
I'm in Ahwatukee/Tempe right near S Mtn. PB said drain every year or 2 but I like to conserve H20. I don't like to fight with algae-extra chlorine isn't good for the environment either. I wish I could say I check my levels on a reg basis but I don't. I end up ultimately fighting algae each year, at least once, which is stupid since I've been on this forum since my build, but it's true. I've struggled with bad salt cells, boards... Last year we ended up paying a company for a brand new Hayward board and cell with 4 yr warranties, but I don't want to be naive and think we going to turn super disciplined about balancing our water and this year the pool won't turn green, even though I'm planning on trying, but each year I think this will be the year I'll be on top of my pool. Historically I've tried to keep chlorine on the lower side and hopefully I've learned my lesson with that, too. Either way, how much am I in for a battle if I don't empty my pool now. If some of you don't mind telling me your pool care "habits" and how often you empty that'd be great!
I have to say I'm at least happy that I'm thinking about getting the pool ready for the season on the earlier side this year
. We were going to break down the filter today but I realized it's been 2 years since draining the pool. From what I recall 3 yrs is stretching it and more work trying to balance the pool (more acid?...), is that true?
So, if it's time, then there's the issue of do I buy or rent a submersible pump or pay someone to empty the pool. In 2018 I bought a pump from Harbor Freight and we were trying to get the pool empty for a warrantee issue and fighting time due to the heat. At that time Dirk said to be careful that an empty pool is subject to the possibility of various mechanical and physical problems, so proceed with caution... With so many times we've tried to fix things on the pool on our own with guidance of TFP a couple of times we just ended up paying someone which ended up being the right answer. I'd think that emptying the pool is easy enough but I'm gun shy with all of our past fails and trying to decide if we throw our hands up and start paying someone to take care of more of more of the infrequent things or continue to try to DIY things like a pool empty. I like DIYing things to a degree, though. What could go wrong with a DIY pool drain? I realize something like making sure the pump was off. When the PB sent out a guy to empty the pool once for a warrantee issue even they messed that one up and I had to shut it off so in the end I'll probably take good enough care unless there's something trickier than that that I don't recall. I'm thinking of the water that sits on the bottom at the end of a drain and remembering the drain screw was stripped, but I don't think that matters cuz from what I recall u just leave the puddle at the bottom of the pool after a full drain.
Thx for your sharing your experience and support ahead of time! It wasn't easy to say I'm not as diligent with my pool as I should be and I'm grateful that 99% of the time this forum is amazingly supportive cuz on many other online places I'd certainly be shamed for that.
