Just keep in mind that if it is open AND exposed to direct sunlight that the bromine will get depleted by the UV in sunlight. So when you are measuring the bromine loss, do so with the cover on.
Sure, you can do that and see how it goes. The pH will tend to rise over time from outgassing. That's why you want the TA lower and (eventually) to put in 50 ppm Borates.
So you have a 43% loss over 12 hours or so. Still quite a high rate of loss. If it were my spa I'd use Ahh-Some and change the water, maybe even more than once if there were a lot of junk coming out from the Ahh-Some. Unfortunately it sounds like if you go that route that your husband will want to just junk the spa completely. I think this is salvageable but it's up to you.
If you wanted to live with it as is, you could do so but would have to add oxidizer to the spa as much as twice a day or certainly a lot every day given the high demand.
So the idea with bromine is that the bromine tabs in the feeder should be able to add enough to keep up with background dosing in between soaks. If you didn't have such a high bromine demand, you'd be able to use the tabs in a feeder for vacations or whenever you weren't using the spa every day.
There are two other alternatives for handling background dosing. One is to have an ozonator and use bromine since ozone will create bromine from a bromide bank (i.e. from the sodium bromide you add initially). The other alternative is to use chlorine with salt and a saltwater chlorine generator such as the ControlOMatic TechniChlor.
OK, if you are going to use just bleach then I definitely recommend you get the borates. You can get boric acid from Duda Diesel or from The Chemistry Store. For your 1000 gallons swim spa to get to 50 ppm Borates you need 59 ounces weight (3.7 pounds) of boric acid.
