So I’ve been adding bleach consistently around five pm each evening after the sun is off the pool. The timer turns off at 7 pm. I run it from 2pm to 7pm ( I was running it 8 but I’m trying to run just the amount needed for clarity and chemical mixing). Is 2 hours sufficient enough to mix the bleach? And when adding cya how long should the pump run after? I’m using hth stabilizer to bump it to fifty (lost about 10 ppm last month due to rain and splash out). I added it directly in the skimmer and ran the pump for about 10 hours after adding. Fifty seems to be a good number for my pool with the amount of full sun and splashout. Pool looks great to me and crystal clear. I’m keeping my chlorine in target range. I dose a little higher to make up for the loss so it doesn’t dip below 7.
