Having a party on Jan 1. Anticipated water temp will be 41 degrees..... I am thinking about heating the Pool to about 83. How many hours (20K Pool) should I plan on to reach the temperature? Expected air temp will be 25 degrees
An 83% efficient 400,000 btu/hr will add 332,000 btu per hour to the water. That's about 2 degrees Fahrenheit per hour. For a 42 degree rise, that's 21 hours with no heat loss. So, that's the fastest possible time.
With heat losses, you can expect the heat up time to be closer to about 38 hours.
Heat losses depend on multiple factors. The difference between air temperature and water temperature is a big factor.
Initially, the losses will be low because the water temperature and air temperature difference is small.
By the time you get close to 83 Fahrenheit, your heat loss could be up to about 200,000 btu/hr.
Your initial net heat gain will be about 1.53 degrees per hour and it will drop to about 0.9 degrees per hour by the time you get to 83 Fahrenheit.
Using a good cover will help you get closer to 21 hours than 38 hours.
I haven't seen a way to "Like" a post on this forum, but I just love these kinds of mathematical explanations!
I think one also has to consider wear & tear on the heater. Running a gas heater for 38 hours straight with it sucking in sub-zero air into the blower/combustor is a recipe for heat exchanger disaster. Incomplete combustion of NG from cold air can lead to the formation of very corrosive condensates on the heat exchanger. So you could wind up shortening the life of the heater considerably unless it happens to be in an indoor pool equipment room.
