- Sep 1, 2011
- 545
- Plaster
- CircuPool Universal40
I have pool with attached spa. Where the line goes out TO the spa, after it leaves the check valve, it goes through about a 14 " long piece of 2" flexible PVC. Over time in the Texas sun, that Flex PVC has cracked and now it is leaking through the PVC. So my question is how do I repair this. I only have about a 2" stub sticking out of the pad where it goes to the spa. If I cut the pipe below the existing coupling, that will be the last cut I can make, because the coupling will be down to the pad at that point. Or is there some way I can remove the coupling without destroying the underlying pipe? Same goes on the check valve end. I would have to remove the Flex PVC without destroying the check valve. Any help would be greatly appreciated. I am attaching an album with related pictures.https://imgur.com/a/wW7XKiu
