How close did I come to killing myself?
HeatTransfer
1
St. Louis, MO
I had just painted the pool, filled it, and was starting to add chemicals. I wasn’t enthusiastic about dropping 5 gallons of boric acid onto my nice new paint, so instead, I drilled some holes in the top of the bucket, shoved the hose in, and kicked it over into the pool like a depth charge. It worked great, I could see the cloud of boric acid coming out of the holes and absorbing into the water before being sucked into the main drain.
That worked so well, I thought I would do the same thing with the 8 lbs of cyanuric acid, that stuff takes forever to absorb, so I put it into the same bucket. The bucket was mostly empty so I thought I’d add the initial shock – about 8 lbs of calcium hypochlorite. I stuck the hose in, went and turned it on, filled the bucket with water, then I got distracted with something else. After about 5 minutes, I heard what sounded like a firecracker. The lid blew of my 5 gallon bucket “chemical diffuser” and then 3 or 4 minutes of “pop, pop, pop” like fireworks from the bucket.
What happened?
(CNOH)₃ + Ca(OCl)2 + H20 = ?
To anyone that reads this, do NOT mix pool chemicals.
Cal-Hypo is a strong oxidizer that releases hypochlorite ions (OCl⁻) and chlorine when dissolved or reacting. In dry form, it’s highly reactive with organic compounds. The oxidizing power of cal-hypo can cause cyanuric acid to break down or chlorinate rapidly, producing chlorine gas and nitrogen trichloride (The reaction isn’t stoichiometric).
C₃H₃N₃O₃ (s) + Ca(OCl)₂ (s) → Cl₂ (g) + NCl₃ (g) + CO₂ (g) + H₂O (l) + Ca-containing byproducts + heat
Chlorine gas is toxic. Nitrogen trichloride is explosive and toxic. The heat can cause the explosion, particularly when confined (like you did in the bucket).
You are very lucky.
Reactions: HeatTransfer
