Hi everyone,
I am trying to determine if there is an issue with my pool since, yesterday, I measured Chlorine in the SWG and I got a reading of about 2-3 ppm. Last week, on Monday, I added salt to my pool since it had almost nothing left and no chlorine was being produced. I set the pump to turn on 2 hours in the morning and 2 hours in the evening but the pool started getting dirtier and maggots starting appearing in the water. Yesterday a friend came over and advised me to leave the pump working for the whole night since 4 hours might not enough to generate the chlorine needed in my pool. I did what he told me and this morning I have found the pool to be much more cleaner (only a few maggots remaining). However, I have just measured now the Chlorine level at the inlet jets and is really, really low. Something like 0.3 or 0.5 ppm. This doesn't make sense to me because if chlorine is being produced at the SWG then why is there so little amount coming out from the jet ? I measured the chlorine level at the far end and I also got the same reading. I set the SWG to 50%, pH is at 7.2 and I have 3 inlet jets. I would really appreciate your help.
