- Mar 8, 2024
- 35
- Plaster
- Hayward Aqua Rite (T-15)
Hey all I want to automate my bubblers and future water slide return. Initially I had just assumed it would be automatically controlled through the Omnilogic app but I was mistaken. Apparently my hub doesn't support any more automated valves and my cheapest option is to add another Omnihub so I can control two more Jandy valves. I was quoted around 2-3k for the install and plumbing. The other more expensive option is to upgrade to bigger omnihub but that will require more expensive plumbing changes and it could be anywhere from 5-6k.
In the picture below the red circle is the jandy valve to control the water going to the water features. The green circle is the ball valve for the bubblers on the baja shelf and the yellow circle is the ball valve for a slide that I will be installing later.
What would be a better solution? I don't need to control the bubblers/slide through the Omnilogic app but I would prefer something that can be controlled through wifi. Thanks!
