Before I bought the house and saw the pool, it just looked like it was dirty. To some degree it was (pic 1), but nothing stood out on the disclosures or inspection. So I buy the house, and after 5 months of renovations I finally move in and the pool was really dirty and green. I put in some shock products from home depot, which cleared up the water, but it revealed what looked like staining (Looking back at pics I took when I bought the house, the same kinds of dirt/stain patterns is there, I just forgot about it). I've been doing all kinds of things to remove the stains. Spot treatments Jack's Copper #2 seemed to clear it right away, so I've been doing that treatment. I also discovered aluminum sulfate also removed the "stains" in spots, so I put a lot in all over the place. Once I realized I wasnt supposed to use it with a DE filter I started to completely drain the pool.
Now as I'm looking at the pool without water, and a lot of the stuff which looked like stains appears isnt a stain but the actual surface, or removing the stains revealed something else. Its a sand color, and looks kinda gritty. It almost looks like two different finishes. So anyone know what is going on? Was this a temporary treatment applied to the original surface, or is this what it looks like when the original surface is degrading. Or is this just something on the surface? When the pool was empty I was going to do an acid wash on any remaining spots, but now all that is on hold. At the moment I'm not really in a position to refurbish it 100% like new, but if there is a bandaid that I can be done now would be a good time since its empty. Or am I seeing the effects of a previous bandaid?
