Taylor K2006 just arrived today.
This evening's readings:
FC: 4.2 ppm
CC: .4 ppm
PH: 7.6
TA: 170
CH: 110
CYA: 35
I still have a bit of haziness after killing off a green algea bloom last week, but the bottom is now visible, so the visibility threat is gone (yay)!
A couple of questions:
What's the best way to bring the TA down?
I actually did the FC test twice. Doing the 25ml test, not all the solids of the reagent dissolved with swirling and the scopper is not long enough to physically agitat them. The first test I used two scoops, and there were so many chunks at the bottom which continued to leach pink color, it took 23 drops to get the water to breifly turn clear. I dumped and rinsed and ran the test again with 25ml and only 1 scoop. There were still some, but fewer solids giving off a constrant stream of pink coloring. This time it took 21 drops. I can't imagine this is normal as it obviously can seriously interfer with test results. This is a brand new kit. Should I return it?
Going to test again in the AM to check for FC loss.
Big question is: Is my pool now safe to swim in?
FC: 4.2 ppm
CC: .4 ppm
PH: 7.6
TA: 170
CH: 110
CYA: 35
