In January, my husband and I bought a 1970's split with a 24' AGP and a six-person StrongSpa hot tub. Mind you, neither of us knew a thing about maintaining pools or hot tubs and just thought "cool, we have a pool and hot tub! Lucky us!" Fast forward to now and it's been a giant learning curve learning how to properly maintain these two beasts. With the help of many on the "pool forum" side, I think we have the pool up and running with the proper balance of good chemicals. Now I am turning my attention to the hot tub and need your expertise on where to even begin.
I have the T100 test kit and these are this evening's results:
Using the K1000: chlorine 0! and confirmed with the chlorine drop test - stayed clear and didn't turn pink
pH 8.2+
CH 50
TA 220
CYA 0 - I haven't added any stabilizer as I didn't know how much or if I use the sock method to add just
like I did with pool
We drained the hot tub back in May and refilled it with the garden hose. We are on a well system out here in the country. The water has never been clear even when the water is "fresh" from the hose. We haven't used it in several weeks and the temperature is maintained at 98 degrees.
Thoughts? Advice? Where do I begin? Thank you so much for your help (in advance) and I'm so thankful for all of you that help all of us newbies!
pH 8.2+
CH 50
TA 220
