Hello MPurcell and Pooldv,
Thank you for the replies.
I have a Hydropool hot tub and the aeration jet is separate from the pressurized self cleaning filtration system. The aeration jet sends a steady stream of fine champagne like bubbles into the hot tub 24/7. If the optional ozonator is installed, they connect the ozone venturi line to the aeration line to introduce ozone into the hot tub. The only filtration option is on 24 hours or off. I am not too concerned about the filtration system running 24/7. When using the hot tub there is an adjustable valve from 1 - 5 to control the amount of air that is injected via the massage jets.
My question is about the aeration jet that injects a steady stream of champagne like bubbles from the bottom of the hot tub. Since I do not have an ozonator I can see no reason to inject bubbles into the hot tub 24/7. Unless there is some other function, which I am not aware of, it seems to me the benefit of disabling the aeration jet will be a reduction in pH drift. As you indicated above that is what I have been experiencing. The pH is rising to 8 and I add dry acid to bring it back down to 7.6 which lowers my TA to 40. I then add baking soda to raise the TA back to 50. And I now suspect the independent aeration jet is the culpret that raises the pH back up toward 8, creating an endless cycle that only adds more stuff to the water.
Unless someone advises another function the aeration jet performs, I will disable the aeration jet supply line and post my results back in a couple of days. If I am correct, with CA 130, TA 50 and Gentle Spa (borates) 50, I should see more stable pH around 7.6. It may even decline with the BCDMH bromine pucks. I do not use MPS. I found 12% sodium hypochlorite (chlorine) to be more manageable. I add 1oz after every use. It raises the bromine above 10ppm and by the next evening it is back down in the 2-4ppm range. Chlorine makes sense to me because that is the C in the BCDMH bromine pucks. The less stuff I introduce into the hot tub the better.
Thank you for all of your help!
